It is currently Wed Sep 17, 2025 1:01 am
 Post subject: Blackwood Bleed?
PostPosted: Mon May 23, 2022 10:05 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I just installed a blackwood rosette in a sitka top and was amazed by the amount of bleed from the blackwood into the end grain of the rosette channel. I didn't seal the channel prior to installing the rosette with Ducco cement, and perhaps that was my downfall. The ducco may have pulled some of the dark colors from the blackwood too. But I usually do not seal the channel unless I'm going to use CA.
Has anyone else ran into blackwood color bleed into adjacent wood? This top is going to go into the experimental bin due both to the color bleed and due to some bad curl in the grain that showed up when sanding.
Tony Thatcher
Bozeman, Montana
 Post subject: Re: Blackwood Bleed?
PostPosted: Mon May 23, 2022 10:39 am
Yes, had that gluing on an (African) Blackwood bridge with HHG to a top, which I had to take off and re-glue.
Fortunately it didn't show as it was side grain gluing and didn't wick into end grain.
PostPosted: Wed May 25, 2022 10:32 am
I'm guessing it's the solvent and heat.
PostPosted: Wed May 25, 2022 5:20 pm
Just curious. If you can shellac the channel and still get a good glue joint, can you also shellac the rosette before installing, to help reduce bleed, and still get a good glue joint?
PostPosted: Wed May 25, 2022 6:37 pm
Don’t know if it would reduce bleed but see no reason you couldn’t.
cron
